Hello rakshitha_r,
From what I understand, you are trying to select all 8 annotations across 3 pages of the PDF. Sometimes when you select those annotations, it is missing the annotations you just ‘drawn/imported’ (from the xfdf)
What is happening is that before you work with the entire list of annotations you have 2 references to the annotationsList: before & after importAnnotations method.
After calling importAnnotations, you can make sure that the annotations are imported by checking annotationManager.getAnnotationsList() then select the annotations. (I think your storedAnnotationList might not be updated)
Also, feel free to create a new forum post if the original topic has been resolved.
