Thank you for contacting us regarding pdfjs and reporting this issue!
We’ve added the issue to our backlog to be worked on in the future. We don’t have a timeline for when it will be fixed but if it does get fixed we’ll let you know when it’s available in an experimental build to test out and the estimated official release date. If you have a desired timeline for having this issue fixed please let us know and we’ll do our best to work with you on how this can fit into the release schedule.
PDFTron Systems, Inc. www.pdftron.com
Thank you for the quick response. We have a hard deadline for the product release within upcoming month. Therefore, we would greatly appreciate if you could add the fix for this issue to the next pdf.express version. This seems to be a critical issue on our end and blocker for the upcoming release.
Thanks for the quick response again. The example file renders properly, but we need more time to test other PDF files with PHI data, so I will write you about results after we finish the testing.
