Adding custom information on shapes and custom items
{Hello,
  1. I’m intrested to know if it’s possible to add custom information on shapes like lines. Basically we are drawing a line and we need to attach some custom informations.
  2. Also we have some items in database and an item has the next properties: id, name, code, description, type, image/ color, otherProperties. We want to draw on the pdf using this items. The item type can be for example, line or a stamp. If it’s line we need to draw a line shape using the properties of the item (in otherProperties for ex we have color). If it’s type stamp we need to use this item as a stamp using the item properties.}
Yes both of these scenerios is possible. Each annotation is just a JS class, so you can assign any properties you like to it. If you need to serialize that data into XFDF, its a bit more involved but definitely possible - let me know if you need help doing this.
For drawing annotations from data in a database, here is a couple resources to get you started.
Basically you just need to load your data from your database, create a the corresponding annotation class, and set its properties based on your database data.
I hope this helps! Let me know if you have any more questions.
