Hi Express team,
I have plan to use the Viewer in my product by placing its inside an iframe similar to the PDF.js viewer are doing, am I eligible to deliver the viewer to users (on different domains) within the iframe , according to the single-domain license?
Would I need to ask customer to grab their own license key for the viewer when using the app?
Many thanks
              Hello beyondspace,
If you are not repackaging the viewer as a purchasable product, but are instead using it within your application it should be fine.
Regarding the separate domains:
If the files are being ran on a separate domain a new key will be needed. However, if you’re embedding a website running the viewer in an iframe (so it only runs on 1 domain) that should work.
              Thanks for the clarification!
              Hello behyondspace,
Of course I would also suggest reading through the license agreement to ensure you’re complying with the terms.
Thank you,
