Any way to prevent WebViewer from doing HEAD request?
‘8.1.0’
When loading document, the viewer tries to HEAD . This is problematic as URLs I give to it are pre-signed S3 URLs and they are not authorizing for HEAD, just GET. Ultimately, WebViewer still works, but creates an exception in console, which might also lead to a minor slowdown.
Have an option to disable HEAD
Every document
Right now we do not have an API to disable this. A HEAD request is made to attempt to get the file type and size before loading it.
However we should be able to add an API to disable this. I’ll add it to our backlog and see what we can do.
Thanks for the feedback,
I too have this issue and I’m unable to upgrade until there is a workaround. version 8.7.0
