Change default zoom level
Is it possible to load a pdf with a different zoom level than the default? Or even better to say that the pdf should take up the full width of the page.
THANKS.
You can use the setFitMode to set the fit mode of the viewer:
https://pdfjs.express/api/UI.html#.setFitMode__anchor
WebViewer(...)
  .then(function(instance) {
    var docViewer = instance.Core.documentViewer;
    var FitMode = instance.UI.FitMode;
    // you must have a document loaded when calling this api
    docViewer.addEventListener('documentLoaded', function() {
      instance.UI.setFitMode(FitMode.FitWidth);
If you want to set the zoom level of the viewer, you can use the setZoomLevel API:
https://pdfjs.express/api/UI.html#.setZoomLevel__anchor
