Custom annotation
8.x.x.x
Am working on custom annotation, onclick of button need to get popup with input fields
on click of the custom annotation button i need one popup with input field, below that some text fields
Yes
useEffect(() => {
path: ‘/webviewer/lib’,
        }, viewer.current).then(async instance => {
        const {Core} = instance;
        //Initially load Document
        instance.UI.loadDocument(myBase64String);
        //to load Annotations
        Core.documentViewer.addEventListener('documentLoaded', async () => {
            const xfdfString = localStorage.getItem("Annotations");
            instance.Core.annotationManager.importAnnotations(xfdfString);
                    // For Pop Up
        instance.UI.contextMenuPopup.update([
                type: 'actionButton',
                label: 'Annotate',
                tooltip: 'Annotate',
                onClick: () => {
                    callAnnotations(instance);
    }) //End of WebView
function callAnnotations(instance) {
console.log(“In callAnnotations”)
//For Form Fields
label: ‘Annotate’,
tooltip: ‘Annotate’,
onClick: () => {
handleShow(instance);
Unfortunately I do not understand what you are trying to accomplish. When you say “on click of the custom annotation button”, what do you mean? What is the “custom annotation button” ? What is the use case?
