Hello, Is it possible to disable the file attachments modal in Multi Tab? My idea is to have my custom modal show when the user selects to add a new file, then use the addTab api to insert the file.
Thank you
Thank you
Hello, I’m Ron, an automated tech support bot ![]()
Guides:Was able to get my custom element to open outside the iframe with the following code.
const viewer = useRef();
const instance = useRef();
const [openFileModal, setOpenFileModal] = useState(false);
//Init Viewer
useEffect(() => {
path: "/webviewer/lib",
licenseKey: process.env.pdfjsExpressLicense,
disabledElements: ["OpenFileModal"],
viewer.current
).then((inst) => {
instance.current = inst;
const { setTheme, enableFeatures, enableElements, Theme, iframeWindow } =
inst.UI;
setTheme(Theme.DARK);
enableFeatures(["MultiTab", "ThumbnailReordering", "ThumbnailMerging"]);
enableElements(["thumbnalsPanel", "thumbnailControl"]);
iframeWindow.document.querySelector(
".TabsHeader .add-button > button:nth-child(1)"
).onclick = () => setOpenFileModal(true);
Hello jrodriguez,
Thank you for sharing your code! however since it doesnt have the full context, I was not able to run it.
We have a custom modal function in our UI that could help:
https://pdfjs.express/api/UI.html#.setCustomModal__anchor
Let me know if that works for you!
PDFTron
