We are trying to add custom elements using dev express controls like dropdown to the header section in the viewer. we were able to add ui control but the dropdown menu position is not with in the viewer iframe and its opening some where in the web application. is there any setting to bound in pdf express viewer?
NA
NA
const renderbutton = () => {
const divElement = document.createElement('div');
divElement.id = 'searchDrpDwn';
divElement.style = 'width:150px';
let dropdownArray = allSearchTermsArray.map((s, i) => ({ elemId: s.elemId, description: s.description }));
$(divElement).dxTagBox({
dataSource: dropdownArray,
placeholder: "select search",
displayExpr: "description",
valueExpr:'elemId',
showSelectionControls: true,
searchEnabled: true,
maxDisplayedTags: 1,
value: searchTermsArray.map(c => c.elemId),
onValueChanged: function (data) {
instance.docViewer.clearSearchResults();
results = [];
searchDropDownClick(data.value);
instance.UI.openElements(['searchPanel']);
return divElement;
async function searchDropDownClick(selectedIdLst) {
for (var selectedElemId of selectedIdLst) {
await performSearch(allSearchTermsArray.find(k => k.elemId == selectedElemId));
const newCustomElement = {
type: 'customElement',
render: renderbutton
instance.UI.setHeaderItems((header) => {
let exiIndex = header.getItems().findIndex(item => item.id == 'searchLst');
if (exiIndex > -1) {
header.delete(exiIndex);
/*header.unshift(newCustomElement); */
header.push(newCustomElement);
