At the start of the Customizing Viewer page here
App level customization
Listen to events on the viewer element and call functions on the varructed PDF.js Express instance. Generally this is the recommended way to customize PDF.js Express within your app.
I’m pretty sure varructed isn’t the word you want.
Craig
Hi Craig,
Thanks for pointing this out! I’ll get this fixed right away.
Zach Serviss
Hey Zach,
You’re welcome. I won’t make a habit of this but now that I have you on the ‘line’:
When you are in the API pages:
https://pdfjs.express/api/
The ‘Events’ dropdown at the top sends you to a 404.
I promise I won’t do this anymore.
Craig
That’s all good! I really appreciate the keen eye.
Zach Serviss
