Hey Logan,
I am facing this bug when I migrated to pdfjs version 8.1.0. So when I convert my text highlight into a rectangle annotation by clicking on it, a copy of the annotation is being created when I focus out of it.
Basically, I am deleting my highlight annotation and adding a rect annotation over it. When I try to manipulate the coordinates of the rect annotation I can see two boxes being formed over it. Let me know if you are able to replicate this on your end. I am attaching some code snippets for your reference.
When I click on my text highlight it should just add a new rectangle annotation over it and delete the text highlight.
Every time in the new pdfjs version
annotManager.on("annotationSelected", (annots) => {
this.annotSelected == true;
if (!this.is_hiddencard) {
if (this.activeState != 'active') {
if (!annots) return;
annots.forEach((annot) => {
// check that our custom 'IsCustomSearch' property is set
if (
annot instanceof Annotations.TextHighlightAnnotation && annot.IsCustomSearch
&& annot.autoHighlights
const { X, Y, Width, Height, PageNumber } = annot;
annot.FillColor = new Annotations.Color(0, 0, 0, 0);
annot.StrokeColor = new Annotations.Color(0, 0, 0, 0);
const textQuad = annot.Quads[0];
const annotNew = new Annotations.RectangleAnnotation();
annotNew.StrokeColor = new Annotations.Color(this.test);
annotNew.FillColor = new Annotations.Color(0, 0, 0, 0);
annotNew.X = textQuad.x1;
annotNew.Width = textQuad.x2 - textQuad.x1;
annotNew.Y = textQuad.y4;
annotNew.Height = textQuad.y1 - textQuad.y4;
//edge cases for X coordinates
if (textQuad.x1 <= 3) {
if (annotNew.Width == annot.getPageWidth) {
annotNew.Quads = [textQuad];
annotNew.PageNumber = annot.PageNumber;
annotManager.addAnnotation(annotNew);
annot.setCustomData("IsHighlightDeleted", true);
annot.deleteCustomData("IsCustomSearch");
const adjustSelectedAnnot = (x, y, event) => {
annotManager.deleteAnnotation(annot, { force: true });
const selectedAnnots = annotManager.getSelectedAnnotations();
if (!selectedAnnots || selectedAnnots.length === 0) {
return;
event.preventDefault();
selectedAnnots.forEach((annot) => {
annot.X += x;
annot.Y += y;
annotManager.redrawAnnotation(annot);
// annotManager.deleteAnnotation(annot);
this.wvInstance.iframeWindow.window.addEventListener(
"keydown",
(event) => {
switch (event.key) {
case "ArrowRight": {
adjustSelectedAnnot(1, 0, event);
break;
case "ArrowLeft": {
adjustSelectedAnnot(-1, 0, event);
break;
case "ArrowUp": {
adjustSelectedAnnot(0, -1, event);
break;
case "ArrowDown": {
adjustSelectedAnnot(0, 1, event);
break;
// Here you can use X, Y, Width, Height
// to create a new Rectangle Annotation!
else if (annot instanceof Annotations.TextHighlightAnnotation &&
annot.IsCustomSearch) {
annotNew.X = textQuad.x1 - 3;
annotNew.Width = textQuad.x2 - textQuad.x1 + 6;
annotNew.Y = textQuad.y4 - 2;
annotNew.Height = textQuad.y1 + 3 - textQuad.y4;
return;
annot.X += x;
annot.Y += y;
"keydown",
(event) => {
break;
case "ArrowLeft": {
break;
case "ArrowUp": {
break;
case "ArrowDown": {
break;
