Embed React component in Web Viewer
Is it possible to embed my own React component within the web viewer?
I would like to incorporate this yellow banner across the web viewer.
N/A
N/A
N/A
You should be able to use React Portals to accomodate this use case.
To use React portals you need a DOM element you want to mount your component to. Since Express does not have one where you want it by default, we can create one like so:
    WebViewer({}).then(instance => {
       const ele = instance.iframeWindow.document.getElementsByClassName('HeaderToolsContainer')[0]
       const div = document.createElement('div');
       div.id = 'login-banner'
       div.style.height = '50px'
       ele.parentNode.insertBefore(div, ele.nextSibling)
This creates an element with the id login-banner inside the UI:
Now inside our React component, we can grab that element to mount our component:
function LoginBanner() {
   const domNode = useRef(instance.iframeWindow.document.getElementById('login-banner'))
  return ReactDOM.createPortal(
          <div>Please log in</div>
    domNode.current
I hope this helps!
Thanks for the help!
