I’m having a problem when I enter some type of elements, and I try to call a function to save, but only with some measure elements, other comment elements don’t give an error
In order to find the exact issue with this problem, could you pin point to exactly which function call this error is happening on?
Zach Serviss
No worries, currently this fix is under review, should be available on our public release early next week.
Zach Serviss
