Hi Logan , Just wanted to confirm if we are doing any scaling in sending y coordinates in pdfjs express. My use case is as follows- I am sending my annotations through a post api from where it will be converted into an image using OCR(mainly using for annotating tables). But the coordinates that are received in the backend do not crop the table efficiently . Is there a scaling that needs to be performed for that? We are mainly having issue with the y coordinates.
Bound info contains the xml file with the coordinates.
annotManager.on(‘annotationChanged’, (annotations, action, { imported }) => {
// If
if (imported) return;
annotManager.exportAnnotCommand().then(xfdfString => {
var formData = new FormData()
formData.append(‘bound_info’, xfdfString)
const headers = new HttpHeaders({ ‘Content-Type’: ‘application/json’ });
headers.append(‘Accept’, ‘application/json’);
fetch(http://3.131.98.86:8000/submittal/upload_file/, {
method: ‘PATCH’,
body: formData,
