| UI version | ‘8.7.0’ |
| Core version | ‘8.7.4’ |
| webviewer.min.js | ‘8.7.4’ |
I created a freetext annotation with pdf.js express plus, then exported as xfdf using annotationManager.exportAnnotations(). I attached the exported xfdf as exported.xfdf.
Then, I imported the xfdf using Acrobat reader onto a pdf. I attached how it looks after importing the xfdf as before_editting.png.
When I double clicked the annotation to edit, it shows body tag and span tag. I attached how it looks after double clicking the annotation as while_editting.png.
When I double click the annotation to edit using adobe reader, xml tags should not show.
This occurs on every document.
We believe this is because of the body tag of contents-richtext in the exported xfdf. On page 9 at Annotation with popup text of the XFDF specification document, the body tag contains xml attributes, where the exported xfdf does not contain any.
attachments.zip (69.7 KB)
