How can I add a spinner or a loader after performing annotations on pdf?
Need to add a spinner/loader on loading annotations or loading pdf into the viewer. Tried using ngx spinner but it will not working inside Webviewer. Any help would be appreciated . Thanks !
You can use the openElements and closeElements APIs to show and hide the built in loading spinner:
    instance.openElements(['loadingModal']);
    setTimeout(() => {
      instance.closeElements(['loadingModal']);
    }, 1000)
For example, if you wanted to display the loading spinner while annotations are loading from your server, you could do something like this:
    initialDoc: 'mydoc.pdf'
}, ele).then(instance => {
   instance.docViewer.on('documentLoaded', async () => {
       const xfdf = await loadAnnotsFromMyServer();
       instance.annotManager.importAnnotations(xfdf);
       instance.docViewer.one('annotationsLoaded', () => {
Hey Logan,
Thanks a lot for the suggestion . It worked well for me. But is there a progress spinner also available which can be shown while the pdf is loaded into the viewer. For large pdf files viewer takes a while to load.
You can use the built in progress spinner for anything you want. You can use a variety of WebViewer events to time when it should be on or off.
For events related to document loaded, take a look at the docViewer events.
