How to add Cloud annotation programatically?
Please fill out the following template as best you can. .
How can I add the cloud annotations programmatically ?
I am adding simple polygon tool like below how to add cloud annotations ?
const createPolygonAnnotations = (annotationData: any, doc: any, Annotations: any, annotationsManger: any) => {
        const polygonAnnotation = new Annotations.PolygonAnnotation();
        polygonAnnotation.PageNumber = Number(annotationData.page);
        const vertices = convertToCoordinateObjects(annotationData.coordinates)
        polygonAnnotation.ga = vertices
        polygonAnnotation.CustomData = {
          addedType: 'programmatically',
return polygonAnnotation;
Hi Shahid,
To clarify, are you referring to this tool in the shapes ribbon group?
Darian
Now it working I just need to se the border style using the setBorderStyle(‘cloudy’)
