Is there any way to auto resize the textbox to fit the content?
Hello, I’m Ron, an automated tech support bot ![]()
Guides:- Rich text
- Customizing WebViewer UI Popups
- Integrating PDF.js Express Viewer with NPM - 2) Copy static files
Hello lakshan,
The FreeTextAnnotation has properties for auto-sizing:
AutoSizeTypes:
NONE string Freetext stays at fixed size
AUTO string Autosize to content
FIXED_WIDTH string Width cannot be changed
FIXED_HEIGHT string Height cannot be changed
https://pdfjs.express/api/Core.Annotations.FreeTextAnnotation.html
Does this work for you?
PDFTron
Hello lakshan,
This is how you use the API:
freeTextAnnotation.setAutoSizeType(instance.Core.Annotations.FreeTextAnnotation.AutoSizeTypes.AUTO)
PDFTron
