How to customize text selection style,I want to change the front and back cursors after selecting text,I haven’t found any relevant introduction in the document, please explain how to do,I would appreciate it
want remove this cursor,I opened the console and found that it was a cursor drawn with canvas,Don’t know how to customize or delete
every
You can do this by creating your own text selection by using the TextSelectionModel API.
You will have to provide your own canvas so that it can be drawn.
Zach Serviss
