cneltyn
September 29, 2020, 12:30pm
1
How to customize the annotations and comments this way: initially we display it as a div with the author, date and the text annotated, but we need to replace the author’s name with some other dynamic value. Is the customization way applicable to pdftron?
any
September 29, 2020, 3:03pm
2
Hi! Thanks for trying out Express.
You can set the author of an annotation dynamically with the setAnnotationDisplayAuthorMap API.
You can also set the current user using the setCurrentUser API.
To change the default name for users you can set the annotationUser property in the constructor options .
I hope this helps! Let me know if there are any more questions.
I’m having trouble setting the user, always returning to me Guest, when I create a new comment
path: '../lib',
initialDoc: '../files/planta-baixa.pdf',
}, this.viewer.nativeElement).then(instance => {
const {annotManager, docViewer, Tools} = instance;
annotManager.setCurrentUser('10010');
annotManager.setAnnotationDisplayAuthorMap((annotation) => {
if (annotation.Id === '10010') {
return 'Alberto Carneiro';
return 'Convidado: ' + annotation.Id;
correction
change annotation.Id to annotation.Author
