Good day,
I tried to add a textpopup and I would like to get the selected text and info once click the Add Tag button, just like the other textPopup button it triggers the event annotationSelected.
instance.UI.textPopup.add({
type: ‘actionButton’,
label: ‘AddTag’,
onClick: () => console.log(‘clicked’),
Thanks.
Hello Mary,
You can use the getSelectedText API under documentViewer to do this.
https://pdfjs.express/api/Core.DocumentViewer.html#getSelectedText__anchor
type: 'actionButton',
label: 'AddTag',
onClick: () => {
const selectedText = instance.Core.documentViewer.getSelectedText();
console.log(selectedText);
Darian
I tried it and it works. Thank you.
