I didn’t understand which event is referring to the ‘selection’ tool.
I need to get the cords and understand if it know give me relative points in scale (zooming) or I need to manually calculate the original X,Y?
Hi daniel-wi,
The selection tool should be using X and Y coordinates in the browser, you can use the windowToPage() API to convert from window to page coordinates.
