Which product are you using? PDF.js Express Version
I’m looking for a way to use PDF JS Express without embedding an iframe on the page. Our product allows the user to right-click on the page with our own custom actions added via a SDK script, and the iframe embed blocks the user from interacting in that way. I noticed that following the iframe src path renders the pdf directly on the page without the iframe, so I assume this is possible.
Is there a recommended way to use this component without creating an iframe?
if I understand well you cannot only load the surface of pdf without any frame around and implement your own controls in a layer above? Could you spare some tips on how to approach this problem?
Or if this is what you are working on, then could I ask when are you approximately planning to implement it?
Unfortunately we do not have an official way of removing the iframe from the product as it is necessary for operation with the UI and namespaces.
PDFTron
