When loading a linearlized PDFs with loadDocument method, the viewer doesn’t show the pdf immediately but wait for the whole file to be fully loaded.
Viewer still in loading state after 206 requests are completed
The viewer show the file immediately if it is linearlized and the server support byte range requests.
Every documents.
My webviewer
document.addEventListener('DOMContentLoaded', function() {
path: url + 'assets/pdfjs-express/lib/',
licenseKey: 'licensekey',
disabledElements: ['printButton', 'downloadButton']
}, document.getElementById('express-viewer'))
.then(instance => {
instance.disableFeatures([instance.Feature.TextSelection]);
instance.UI.disableFeatures([instance.UI.Feature.Print]);
instance.UI.disableFeatures([instance.UI.Feature.Download]);
instance.setLanguage('vi');
instance.setLayoutMode(instance.LayoutMode.Single);
instance.setCustomPanel(customPanel);
instance.openElements(['leftPanel']);
instance.setActiveLeftPanel('customPanel');
instance.loadDocument(url + 'getfile/' + document.getElementById('book-id').value, {
extension: 'pdf',
documentId: document.getElementById('book-id').value
My PHP server:
$fileSize = filesize($pdfPath);
$this->response->setHeader('Accept-Ranges', 'bytes');
$rangeHeader = $this->request->getHeaderLine('Range');
if ($rangeHeader) {
if (preg_match('/bytes=(\d*)-(\d*)/', $rangeHeader, $matches)) {
$start = $matches[1];
$end = $matches[2];
if ($start === '') {
$start = $fileSize - $end;
$end = $fileSize - 1;
} elseif ($end === '') {
$start = (int)$start;
$end = (int)$end;
if ($start >= $fileSize || $end < $start) {
return $this->response->setStatusCode(416)->setBody('Range Not Satisfiable');
$length = $end - $start + 1;
$file = fopen($pdfPath, 'rb');
fseek($file, $start);
$buffer = fread($file, $length);
fclose($file);
$this->response->setStatusCode(206);
$this->response->setHeader('Content-Range', "bytes {$start}-{$end}/{$fileSize}");
$this->response->setHeader('Content-Length', $length);
return $this->response->setHeader('Content-Type', 'application/octet-stream')->setBody($buffer);
return $this->response->setStatusCode(400)->setBody('Invalid Range header.');
} else { //Send the whole file
$rangeStart = $fileSize - 1;
$this->response->setHeader('Content-Range', "bytes 0-{$rangeStart}/{$fileSize}");
$this->response->setHeader('Content-Length', $fileSize);
return $this->response->setHeader('Content-Type', 'application/pdf')->setBody(file_get_contents($pdfPath));
