No license key was provided, running in demo mode
Core version 7.3.3
No license key provided message on production environment, correct domain associated
Remove watermarks from PDFs
Issue happens with every document
No link, downloads to local files
        let element = document.getElementById('viewer');
            licenseKey: 'my_licensekey',
            path: '/pdfjs-express',
            initialDoc: pdf_url,
            ui: 'legacy'
        }, element).then((instance) => {
Are you able to point me to the URL where you are seeing this issue? The only place we have an error message like that is in our rest API utilities - so I do not believe this is coming from Express itself.
Do you have some code like this somewhere?
import Utils from '@pdftron/pdfjs-express-utils'
const util = new Utils({})
Not providing license keys to this constructor will show that warning.
Yes, we have this
     import ExpressUtils from '@pdftron/pdfjs-express-utils'
                ui: 'legacy'
                const { docViewer, annotManager } = instance;
                this.webviewer_instance = instance;
                this.webviewer_instance.utils = new ExpressUtils()
Where should we define again the license key?
Here you can access to a live page example:
https://searchlook.mx/webviewer?tkn=Im9tYXJlZDQ5MTJAaG90bWFpbC5jb20i.YP9qew.0iIOc9PEnVVPXim4VbgNhjHviBY
Thanks for the code and the link. I do not see a watermark on your viewing, which means your express key is working as expected.
The log you are seeing is coming from this line: this.webviewer_instance.utils = new ExpressUtils()
You are instantiating the library without an API key (which is OK - the log is just letting you know). Here are the docs for the library.
But all files are being received with the watermark text: “PDF.js Express Dev mode” in red color
Is it because no API key is provided?
Yes, the REST API needs a separate license key which you can get from PDF.js Express.
See this page for more info.
