PDFJSExpress can’t worked on Firefox, It returns the error “NS_ERROR_FAILURE”. Is this the reason behind this issues?
PDFJSExpress working fine in Google Chrome. Please provide suggestion so we can solve on our end.
It looks like you are using Express inside a modal - are you setting display: none on that modal by chance? Firefox has a bug where setting display:none on an iframe or an iframes parent breaks the contents of that iframe.
To work around this bug you can instead set the element to visibility: hidden or height: 0; width: 0; .
Thank you for your reply. Loaded PDFJS in ifram and it has worked of us.
