Using Create React App, PDFs do not display when project has been run as build. Instead, the iframe just shows a redirect to the main app index.
This problem can be seen even by running a build version of the Create React App demo you have provided in Github. GitHub - pdfjs-express/pdfjs-express-viewer-react-sample
PDFs should load in iframe, just as in development mode.
All documents
Document is in public/files in dev mode, and gets copied to build/files in build version.
useEffect(() => {
/** Currently using a free tier, so not worried about this being is source code */
licenseKey: "XXXXXXXX",
path: "/webviewer/lib",
initialDoc: "/files/document.pdf",
viewer.current
).then((instance: any) => {
const { Core } = instance;
Core.documentViewer.addEventListener(
"pageNumberUpdated",
(pageNumber: any) => {
if (pageNumber === 8) {
setViewedEntireDoc(true);
