Receiving Invalid PDF Structure message when converting base64 to blob
express plus
I am trying to load a document from base64 string. I am converting it to a blob but when the document loads I receive an error on the viewer saying " ERROR. Invalid PDF Structure" I am following the documentation and need help deciphering what I am missing.
I expect to receive a base64 image string, covert it to a blob, and be able to see it in the pdf viewer
every document
function base64ToBlob(base64) {
  const parts = base64.split(';base64,')
  const decodedData = window.atob(parts[1]);
  const bytes = new Uint8Array(decodedData.length);
  for (let i = 0; i < decodedData.length; ++i) {
    bytes[i] = decodedData.charCodeAt(i);
  return new Blob([bytes], { type: 'application/pdf' });
export const PdfViewer = () => {
 const viewer = useRef(null)
 const sampleImage = '"data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAUAAAAFCAYAAACNbyblAAAAHElEQVQI12P4
  //8/w38GIAXDIBKE0DHxgljNBAAO9TXL0Y4OHwAAAABJRU5ErkJggg=="'
 const imageBlob = base64ToBlob(sampleImage);
  useEffect(() => {
       path: '/webviewer/lib'
       viewer.current
        .then(instance => {
          instance.UI.loadDocument(imageBlob, { filename: 'myfile.pdf' });
          documentViewer.addEventListener('documentLoaded', () => {
            // perform document operations
Hi @jessi.0157,
Looks like that string has two different quote styles in it. Please use just one.
Zach Serviss
Platform Support Engineer
That was a typo while writing the question. Original code does not contain two quote types.
Can you please share the proper string?
Zach Serviss
 const sampleImage = 'data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAUAAAAFCAYAAACNbyblAAAAHElEQVQI12P4
  //8/w38GIAXDIBKE0DHxgljNBAAO9TXL0Y4OHwAAAABJRU5ErkJggg==';
Thank you.
I think the problem here is that the data type is image, it should be application/pdf.
Zach Serviss
