Viewer black on android mobile iframe
I’m facing a problem with viewer on android mobile view, the viewer works perfectly with the desktop mode (windows, android and IOS), but the pdf is not loading when using android mobile ( i havn’t test with ios mobile since i don’t have an iphone right now).
GIF-220330_175333
You can see with the gif that the viewer works when using desktop view, and that on mobile, only the left panel show the pdf.
The issue does not come from chrome since the demo here How to Embed a PDF in an HTML Website | PDF.js Express works perfectly. I’m guessing that i’m misssing something. I’m not good with java script and i had trouble finding documentation on the website talking about iframe.
Thank you very much for you help
Here is my code for the viewer
    <div class="col-md-6">
        <div class="card">
            <div class="card-body">
                <!-- Errors out -->
                <div id='labo' style='height: 75vh; width: 100% ;'></div>
            </div>
        </div>
    </div>
Here is the gif with desktop view
ezgif.com-gif-maker
Here the script
            path: 'plugins/pdf-js/lib', // path to the PDF.js Express'lib' folder on your server
            licenseKey: 'key',
            initialDoc: 'mypdf.pdf',
            // initialDoc: '/path/to/my/file.pdf',  // You can also use documents on your server
        }, document.getElementById('labo'))
        .then(instance => {
            const {
                Core,
                UI
            } = instance;
            Core.documentViewer.addEventListener('pageNumberUpdated', (pageNumber) => {
Couple questions for you:
  • Do you see any errors in the console?
  • Does the document show up if you zoom in/out?
  • Does the document show up if you wait a few seconds?
