Core version 8.3.0
UI version 8.3.2
Entered the correct license key linked to my domain, but watermarks are still showing
PDf to display without watermarks
Every time
https://box10.co.uk/work/tapestry/index.html
system
3
Guides:
APIs:
Forums:
thanks for your help
but i have used multiple browsers and private mode, and the watermark is still there
6
You are using the wrong NPM package. Please make sure you are using @pdftron/pdfjs-express-viewer and not @pdftron/pdfjs-express
Hi Logan
Thank you so much. all working now
Russell
