XFDF too big, lenght exceeded
Hello, pdfjsexpress is returning this
HTTP content length exceeded 10485760 bytes.
What can we do to improve that?
{Description here}
Hello suporte,
We have a section on this at the bottom of this page: PDF.js Express API Errors | Documentation
PDFTron
Hello @tgordon, thanks for the reply.
We are already sending the url address within the PDF.
im attaching here the PDF file and a print of our code.
Also on this google drive link you can find .txt xfdf
wilson.pdf (4.0 MB)
Hello guys, any news on this matter?
Hello suporte,
Can you provide the URL you are using for this document?
PDFTron
Hello Tyler, yes.
link follows:
https://api.dattasign.com.br/api/file_view
Hello
Any news about this matter?
Hello suporte,
Apologies for the delay. I was able to get it working with this code:
 data.append('xfdf', xfdf);
    await fetch('https://api.dattasign.com.br/api/file_view').then( async (resp) => {
      data.append('file', await resp.blob())
      const response = await fetch('https://api.pdfjs.express/xfdf/merge',
          method: 'post',
          body: data
        }).then(resp => resp.json());
      const { url, key, id } = response;
After converting the response to a blob it worked.
PDFTron
Hello @tgordon,
We did test this solution, but did not work.
The problem isnt the File, the problem is the XFDF is larger than the size that HTTP allows
XFDF follows:
@tgordon Hello mate, sorry for disturbing, any news about this?
Hello suporte,
Apologies for the late reply, we have been experimenting to see if we could get this large XFDF to merge in the API. I think the limitation of the HTTP size results in this merge to be impossible. I tried posting the XFDF to a secret GitHub gist and fetching it, then fetching the file, then putting those blobs into the merge API however it still resulted in a 413 error.
I think the workaround here would be to export the annotations in chunks, say you have 10000 annotations, you would export 1000 at a time, then make multiple calls to merge them.
I have attached the code I have been testing with, that includes the XFDF GitHub gist link
index 2.js.zip (1.1 KB)
PDFTron
Hello, @tgordon!
You PDF.js Express team could do for xfdf as you already do for the file process. For example, for xfdf larger than 5.5mb, it would send the xfdf via URL.
What do you think of this update?
Vicente!
Hello vicente,
We don’t currently have this on our roadmap but we will add it to the backlog for our product team to review.
PDFTron
