We have the tooltipName that you can use for when hovering over the checkbox.
Let me know how that works for you.
You have the position of the checkbox widget at (100, 100) from
widgetAnnot.X = 100;
widgetAnnot.Y = 100;
You can create a free-text annotation to the left of the widget following this guide:
