UI Version = 8.7.0
Core version = 8.7.5
I’ve added an onClick function to call some code when the user clicks on the signature and rubber stamp buttons. When I click the signature button when it is active, it highlights the edit tool but it does not deselect the signature tool.
The default behaviour of the application is that when a tool is active and the user clicks on it again, the edit tool is selected and the Add New Signature in the drop down changes to No Presets.
I’ve added similar code for the rubber stamp button and this works as expected.
I expected that the signature button would be deactivated and that the edit tool would be enabled. This is what happens with the onClick function for the rubber stamp tool that I have included in the code snippet.
Every document
N/A
I used this code on the PDF.js Express demo in the console and it showed the same behaviour.
const instance = WebViewer.getInstance();
instance.UI.updateElement('signatureToolGroupButton', {
onClick: () => {
if(instance.getToolMode().name === instance.Tools.ToolNames.SIGNATURE) {
instance.setToolMode(instance.Tools.ToolNames.EDIT);
instance.setToolMode(instance.Tools.ToolNames.SIGNATURE);
instance.UI.updateElement('rubberStampToolGroupButton', {
onClick: () => {
if(instance.getToolMode().name === instance.Tools.ToolNames.RUBBER_STAMP) {
instance.setToolMode(instance.Tools.ToolNames.RUBBER_STAMP);
