Adding the initialDoc path in Java JSP Struts project
{ I’m working on a Java JSP Struts project which has previously implemented PDF.js for previewing documents. Because of the the PDF.js library didn’t support watermarks option I decided to move to PDF.js Express.
The getImage.do will go to the GetImageAction.java page and generate and get the PDF file,
I have added the previous implementation code below.
I have tried to add the previous location URL path like this
encodeURIComponent('${pageContext.request.contextPath}/getImage.do?imageDocID='+document.getElementById('imageDocID').value);
but this is not a file path, so the webViewer shows this error by identifying .do as the file extension.
File extension do%3fimagedocid%3dww222244 is not supported. Please see http://r.pdftron.com/fileformats for a full list of file formats supported by WebViewer. If this file is actually valid then you can pass the 'extension' option with the intended file extension e.g. const doc = await Core.createDocument("http://domain/file11243. php", [extension: "pdf"}) the initialDoc value is %2FWEB_SSD%2FgetImage.do%3FimageDocID%3DWW222244
So do you any other method to add the initialDoc value as my previously implemented method?
{ I want to view the generating PDF via the pdf.js express viewer.}
{Every Document}
{The document is created as a byte stream, So I don’t have any document location to add it the initialDoc property.}
The below code snippet is the previous implementation
html body
<iframe id="content" style='height: 600px; width: 98%; min-width: 900px;' scrolling="no" src=""></iframe>
script
<script type="text/javascript">
    $(document).ready(function() {
        var base='web/viewer.html?file=';
        var subUrl=encodeURIComponent('${pageContext.request.contextPath}/getImage.do?imageDocID='+document.getElementById('imageDocID').value);
        var url=base+subUrl+'#page=1';
        $('#content').attr('src',url);
</script>
struts-config
<action
    path="/getImage"
    type="web.ead.webapp.ssd.common.action.GetImageAction"
    scope="request">
</action>
GetImageAction.java
public class GetImageAction extends GenericAction {
    static Object imageServerLock = new Object();
    public ActionForward execute(ActionMapping mapping, ActionForm form,
            HttpServletRequest request, HttpServletResponse response)
    throws IOException, ServletException, Exception {
        UserProfile userProfile = (UserProfile) request.getSession().getAttribute("UserProfile");
        ActionForward actionForward = null;
        String imageDocID = request.getParameter("imageDocID");
        if (actionForward == null)
            byte[] appletData = ImageManager.getMod2TifImage(imageDocID);
            ObjectOutputStream outputToApplet = new ObjectOutputStream(response.getOutputStream());
            outputToApplet.writeObject(appletData);
            outputToApplet.flush();
            outputToApplet.close();
        return actionForward;
        try{
            actionForward = super.execute(mapping, form, request, response);
            System.out.println(new Timestamp(System.currentTimeMillis()).toString() + "\trequest.getRemoteAddr() "
                    + request.getRemoteAddr()
                    + " Utility.getClientIp(request) : "
                    + Utility.getClientIp(request) + " - " + imageDocID
                    + " UserProfileID: " + userProfile.getUserProfileID());
            byte[] image = null;
            synchronized (imageServerLock) {
                if(request.getSession().getAttribute("IMAGE-"+imageDocID) != null)
                    image = (byte[]) request.getSession().getAttribute("IMAGE-"+imageDocID);
                if (actionForward == null) {
                    byte[] dest = addWatemark(image);
                    try{
                        PdfReader reader = new PdfReader(dest);
                        int pages = reader.getNumberOfPages();
                    }catch(Exception ex){
                        ex.printStackTrace();
                        image = ImageManager.optimizePDF(image);
                    response.setContentType("application/pdf");
                    OutputStream outs = response.getOutputStream();
                    outs.write(dest);
                    outs.close();
                        request.getSession().removeAttribute("IMAGE-"+imageDocID);
        }catch(Exception e){
            e.printStackTrace();
        LoggerUtils.info(this.getClass().getName() + " - execute method --> Exit");
Hello ravinduyasithgtx,
Can you provide a minimal runnable sample to reproduce the issue, since this integration is complex.
Hello tgordon,
Simply, is there any way to load the pdf file if I have the byte stream?
In my project the PDF file generated as an byte stream, because of that in the WebViewer initialDoc property I cannot set a byte stream.
I just need to know that how to input a byte stream to the PDF.js Express.
Thank you
If you convert the bytestream into a usable state like a ArrayBuffer or Blob, you can then call loadDocument or the initalDoc parameter.
Hello tgordon,
	function getPDFData(imageDocID) {
        // Get the PDF data from the `getImage.do` action
        var xhr = new XMLHttpRequest();
        xhr.open('GET', '${pageContext.request.contextPath}/getImage.do?imageDocID=' + imageDocID);
        xhr.responseType = 'arraybuffer';
        xhr.onload = function() {
        	console.log(xhr.status);
            if (xhr.status === 200) {
            	console.log(xhr.response);
                // Return the PDF data
                return xhr.response;
                // Handle error
                console.log('Error getting PDF data: ' + xhr.statusText);
        xhr.send();
  path: './pdfJSExpress/lib', // path to the PDF.js Express'lib' folder on your server
  licenseKey: 'xxxxxxxxxxxxxxxxxxxxxx',
  loadDocument: getPDFData(document.getElementById('imageDocID').value),
}, document.getElementById('content'))
.then(instance => {
  Core.documentViewer.addEventListener('pageNumberUpdated', (pageNumber) => {
</script>
The getPDFData method returns an ArrayBuffer. But I couldn’t view the pdf file.
Thank you.
I’m not exactly sure how this would work because I do not have a runnable sample, however, I suggest calling your XHR request after the documentLoaded event is fired by WebViewer. This ensures the PDF data is ready to be fetched.
