When trying to load a test pdf from azure storage blob, the server url is there.
It was working fine in an older version.
This is happening with the web viewer for all pdfs
path: ‘…/lib’,
initialDoc:‘https://submittalappstg.azurewebsites.net/api/Home/download?bloburl=Update_d810adcf-fb46-41f0-9f0f-e2246cc86399.pdf’,
licenseKey: ‘irld89CMAcwPvMz4SJzz’,
}, this.viewer1.nativeElement).then(instance => {
debugger;
this.wvInstance = instance;
this.wvInstance.annotManager.setCurrentUser(this.user)
var files = this.dialogConfig && this.dialogConfig[‘pdfFiles’];
if (files && files.files && files.files.reorderIndexes) {
try {
let reorder = JSON.parse(files.files.reorderIndexes)
if (Array.isArray(reorder)) {
this.reorderData = files.reorderData = reorder
catch { }
this.createHeader(this.dialogConfig.config.previewUrl, files);
instance.setFitMode(‘FitWidth’)
instance.openElements([‘notesPanel’]);
instance.disableFeatures([instance.Feature.Print, instance.Feature.FilePicker]);
instance.disableElements([
‘menuButton’, /* for menu /
‘searchButton’, / for search /
‘toolsButton’, / full screen /
‘miscToolGroupButton’, / stamp, attachment, callout /
‘stickyToolButton’, / comment box /
‘signatureToolButton’, / signature /
//‘zoomOverlayButton’, ‘zoomInButton’, ‘zoomOutButton’,
‘panToolButton’,/ hand /
‘viewControlsButton’, / settings, page transition, layout, rotate /
‘selectToolButton’ / big arrow */,
‘ellipseToolButton’,
‘arrowToolButton’,
‘polylineToolButton’,
‘polygonToolButton’,
‘cloudToolButton’,
‘freeHandToolButton2’,
‘freeHandToolButton3’,
‘freeHandToolButton4’,
‘highlightToolButton2’,
‘highlightToolButton3’,
‘highlightToolButton4’,
‘underlineToolButton’,
‘squigglyToolButton’,
‘strikeoutToolButton’,
‘outlinesPanelButton’,
‘documentControl’
