Core Version: 8.7.4
We load PDFs and allow users to annotate and reply via the PDF.JS UI. We have a download button that’s implemented by calling the /merge endpoint to merge all annotations into the PDF. Finally, we download with the URL from the API response.
When a user leaves a comment and then replies to it, the reply is “nested” correctly in the UI. But when downloading and opening the PDF in Adobe, the reply is a top-level comment. I checked the xfdf string, we pass to the API and it has the “inreplyto” set on the reply in question (we don’t create those xfdf strings ourselves though, see code).
I’d expect the reply to appear as a reply in Adobe after download.
All
const { docViewer, annotManager } = pdfInstance;
const fileData = await docViewer.getDocument().getFileData({});
const blob = new Blob([fileData], { type: 'application/pdf' });
const xfdf = await annotManager.exportAnnotations({ annotList: annotManager.getAnnotationsList(), links: false, widgets: false });
const data = new FormData();
data.append('xfdf', xfdf);
data.append('file', blob);
data.append('license', '...');
const response = await fetch('https://api.pdfjs.express/xfdf/merge', {
method: 'post',
body: data,
}).then((resp) => resp.json());
