tristan
September 19, 2023, 5:58pm
1
PDF.js Express Version 8.7.0
when group annotations, some of them disappear
when ungroup annotations, all annotations disappear
should save annotations properly when group and ungroup
Every document
I currently save the annotations to the database, using action cable to have the realtime collaboration.
Sometimes the grouping work, but almost of the time it doesnt work like the video I put above.
My question is how can I detect the grouping/upgrouping event, and which is the proper way to handle them?
tgordon
September 20, 2023, 3:26pm
3
Hello tristan,
How, and when are you saving the annotations to the database?
It could be the timing is off and not saving the correct annotations.
Thank you,
tristan
September 21, 2023, 5:50am
4
Hi @tgordon , thank you.
My code looks like
annotationManager.addEventListener(
"annotationChanged",
(annotations, type, { imported }) => {
annotations.forEach((annotation) => {
annotationManager.exportAnnotationCommand().then((xfdf) => {
if (type === "add") {
// Call the API to save the annotation to the database with xfdf
} else if (type === "modify") {
// Call the API to update the annotation to the database with xfdf
} else if (type === "delete") {
// Call the API to delete the annotation to the database with xfdf
tgordon
September 21, 2023, 6:35pm
5
Hello tristan,
I would suggest instead just using:
Since annotations in command form already have the add/delete/modify commands and when merged with the API it will add/delete/modify based on those commands.
tristan
September 22, 2023, 7:05am
6
@tgordon but even I do not call API to save it to the database, I just want to see the xfdf through console.log, its not correct.
When I do the group, from 2 annotations => 1 annotation with xfdf data and 1 empty xfdf.
When I do the ungroup, I can not make it back to 2 annotations like before I group.
Currently, each annotation I save it in a separate record in the database.
Im following this doc, but the my tech stack is Rails, Actioncable, Posgresql: Client Setup for Collaborating with PDF.js Express | Documentation
I want to know how can I detect the event is group, or ungroup => I can merge and unmerge the xfdf.
Thank you
tgordon
September 22, 2023, 6:17pm
7
Hello tristan,
Can you provide the XFDF from the operation?
tristan
September 25, 2023, 6:05am
8
Separated:
First XFDF
<?xml version="1.0" encoding="UTF-8" ?>
<xfdf xmlns="http://ns.adobe.com/xfdf/" xml:space="preserve">
<fields />
<add><square page="0" rect="92.940,448.780,221.020,531.530" color="#00CC63" flags="print" name="b4632233-1991-70be-a0ed-5fe5a968afb1" title="7" subject="Rectangle" date="D:20230925143830+07'00'" interior-color="#E2A1E6" creationdate="D:20230925143829+07'00'"/></add>
<modify />
<delete />
</xfdf>
Second XFDF
<fields />
<add><square page="0" rect="321.900,439.720,461.320,536.060" color="#00CC63" flags="print" name="3f860c93-45df-4a71-d1c3-8be411875e5a" title="7" subject="Rectangle" date="D:20230925143855+07'00'" interior-color="#E2A1E6" creationdate="D:20230925143854+07'00'"/></add>
<modify />
<delete />
</xfdf>
After group
First XFDF
<fields />
<add />
<modify><square page="0" rect="92.940,448.780,221.020,531.530" color="#00CC63" flags="print" inreplyto="3f860c93-45df-4a71-d1c3-8be411875e5a" replyType="group" name="b4632233-1991-70be-a0ed-5fe5a968afb1" title="7" subject="Rectangle" date="D:20230925143911+07'00'" interior-color="#E2A1E6" creationdate="D:20230925143829+07'00'"/></modify>
<delete />
</xfdf>
Second XFDF
<fields />
<add />
<modify />
<delete />
</xfdf>
tristan
September 25, 2023, 10:19am
9
Note: we are trying to save each annotation as each row in the database and want it to work in real-time collaboration.
If I use exportAnnotations instead of exportAnnotationCommand
I got the following
Before group
<xfdf
<annots>
<square page="0" rect="156.420,595.000,232.360,650.540" color="#00CC63" flags="print" name="8488d4a4-e433-0cfb-7a1e-f61185db200d" title="7" subject="Rectangle" date="D:20230925171711+07'00'" interior-color="#E2A1E6" creationdate="D:20230925171710+07'00'"/>
</annots>
</xfdf>
<xfdf
<annots>
<square page="0" rect="283.360,599.530,378.570,657.340" color="#00CC63" flags="print" name="f44e3dbf-c204-eaf9-58b8-bd3583aaca26" title="7" subject="Rectangle" date="D:20230925171744+07'00'" interior-color="#E2A1E6" creationdate="D:20230925171743+07'00'"/>
</annots>
</xfdf>
After group
<xfdf
<annots>
</annots>
</xfdf>
<xfdf
<annots>
<square page="0" rect="156.420,595.000,232.360,650.540" color="#00CC63" flags="print" inreplyto="f44e3dbf-c204-eaf9-58b8-bd3583aaca26" replyType="group" name="8488d4a4-e433-0cfb-7a1e-f61185db200d" title="7" subject="Rectangle" date="D:20230925171822+07'00'" interior-color="#E2A1E6" creationdate="D:20230925171710+07'00'"/>
</annots>
</xfdf>
