Can i integrate pdf.js express to my java project using cdn js and how can i get a free trial key?
I’m working on plugin developement and i want to integrate a viewer to my project using pdf.js express in the case of using annotations, that why i want to know if i can use it with pure javascript ? does any CDN available? and can i get a free trial key?
Yes, PDF.js Express is written in Vanilla JS and does not rely on any frameworks, meaning you can use it in every JS application.
We do not host it on a CDN, but it is available via NPM. You can also download it manually
You can try Express without a license key. A license key is only required once you move into production.
