I am making a website of schematics stored as pdf files. Each pdf will be on it’s own page accessible by a UPC label. First page works but when I create another page the document doesn’t load. Error message displayed in console is "A valid license key is required to use the view only build of PDF.js "
{To load the pdf file passed into the viewer}
{With every document but the first one}
path: ‘/test/PDFJSExpress-view-only/lib’, // path to the PDF.js Express’lib’ folder on your server
licenseKey: ‘xxxxxxxxxxxxxx’,
initialDoc: “/test/Model.pdf”}, document.getElementById(‘viewer’))
.then(instance => {
