Pdfjs express viewer not loading the document - Invalid key
@pdftron/pdfjs-express-viewer
UI version: 8.4.1
Core version: 8.4.0
I am upgrading my app that uses pdfjs-express version 6 (UI 6.2.0, Core 6.2.1) to pdfjs-express-viewer version 8, I am using the same license key that works on the previous code but I am getting below error when trying to view the document:
Error: PDFJS.express: A valid license key is required to use the view only build of PDF.js Express. Get your free license key at https://pdfjs.express/profile (account required)
The issue happens on all documents
    path: '{{ url_for('static', filename='js/pdfjs-express-viewer') }}/public',
    licenseKey: 'zzzzzz,
    initialDoc: '{{ url_for('static', filename='docs') }}/doc2.pdf',
  .then(instance => {
Hi there, pdfjs-express and pdfjs-express-viewer are different products with different license keys. Please make sure you are using the right product for your license key.
Please also check out this post.
If none of that works please reply here and we can investigate further.
Thank you for your assistance.
I managed to find the issue. I was using 127.0.0.1 to try to view my documents instead of localhost (The keys’s domain was tied to localhost), pdf express viewer seems to make a difference between the 2.
