Pdf.js Express Viewer
couldn’t use searchtext API for next search result
docViewer.addEventListener(‘documentLoaded’, () => {
instance.UI.searchText(searchValue, {
caseSensitive: false,
wholeWord: false
i just call this, on first search it complete , but after i search same word again, it has error and won’t go to next search value
every documents, i did try to create new project and create new instance, the problems are the same
(Basic searching | Documentation)
