I’m using textSearchInit API to search for something in my document but I don’t see any search done in the pdf viewer or any output on the console. Is it because annotations are not supported in the pdf js express viewer?
The search should happen and relevant string should be highlighted in the viewer
Yes
path: '/static/assets/pdfjs-express-viewer',
licenseKey: '',
initialDoc: pdfpath,
enableAnnotations: true
// initialDoc: 'https://pdftron.s3.amazonaws.com/downloads/pl/webviewer-demo.pdf',
.then(instance => {
const {Core, UI} = instance;
UI.disableElements(['rightPanel']);
UI.disableElements(['leftPanel', 'leftPanelButton']);
pdfjs_instance = instance
pdfjs_docviewer = Core.documentViewer
console.log('Document loaded');
const {
documentViewer,
Core2,
annotationManager,
Annotations
} = instance.Core;
// Set search modes. See the API reference for more information
const searchMode = Core.Search.Mode.PAGE_STOP | Core.Search.Mode.HIGHLIGHT;
const searchOptions = {
fullSearch: true, // search the full document
onResult: (result) => {
console.log('Search done')
if (result.resultCode === Core.Search.ResultCode.FOUND) {
if (!result.quads.length) return;
console.log(result);
const textQuad = result.quads[0].getPoints();
const annot = new Annotations.TextHighlightAnnotation();
annot.X = textQuad.x1;
annot.Width = textQuad.x2 - textQuad.x1;
annot.PageNumber = result.pageNum;
annot.Y = textQuad.y3;
annot.Height = textQuad.y1 - textQuad.y3;
annot.FillColor = new Annotations.Color(0, 0, 255, 0.5);
annot.StrokeColor = new Annotations.Color(0, 0, 255, 0.5);
annot.Quads = [textQuad];
annotationManager.addAnnotation(annot);
annotationManager.drawAnnotationsFromList([annot])
// start the search
documentViewer.textSearchInit('Strata', searchMode, searchOptions);
