Checkbox selection issue
I am facing issue while rendering the PDF file using webviewer.
Issue is that I have checkboxes in PDF file. When I select the checkboxes inside PDF file that rendered in WebViewer (@pdftron/pdfjs-express), it automatically selects adjacent checkbox with clicked checkbox.
Hello basilravi,
Does this happen with every PDF with Checkboxes? or specific files?
If its with specific files, can you provide a document that has this bug?
PDFTron
@tgordon Thanks for quick response.
It is happening for a specific file.
2022 CFC - Tech Renewal Application (1).PDF (426.8 KB)
Ravi
Hello basilravi,
I loaded the file into the latest version of PDFJS Express and the checkboxes are behaving as expected.
PDFTron
Hello @tgordon
Please find the reponse of queries
  1. What version are you running?
    “@pdftron/pdfjs-express”: “^7.3.0”,
    “@pdftron/webviewer”: “^7.2.0”,
  2. Can you reproduce this on the demo page? PDF.js Viewer Demo | PDF.js Express
    Nope. It working fine on demo
  3. What browser are you using?
    Chrome
Ravi Basil
Hello basilravi,
Since its no longer reproducible in the latest version, I recommend updating.
Here is the migration guide from v7.x → v8.x Migrating to PDF.js Express 8.0 | Documentation
Best regards
PDFTron
