In the demo, the text select & pan is working fine
Demo
But in in the React example, the select & pan feature is not working.
React
And I notice there is this error message whenever I’m performing any click.
Hello @shumkapoh
Indeed, I was able to reproduce the issue. This will be fixed in the next version (8.8.0), but in the meantime, as a workaround, could you try the attached folders and let me know if this works for you?
The only thing you need to do is replace the UI and core folders inside public/webviewer/lib with these two ones attached. Please remove the old ones first before pasting the new folders in.
Archive.zip (6.9 MB)
Is there a similar zip file with a fix for the @pdftron/pdfjs-express-viewer version? This zip file seems to be for the @pdftron/pdfjs-express version.
Can you provide a release date for v8.8.0?
Hi twidel,
Please try this build:
PDFJSExpress-view-only-8.7.0.zip
We are no longer releasing new versions of PDFJS Express, and instead are updating v8.7 with bugfixes.
PDFTron
Thank you @tgordon, that worked.
Any chance you can update NPM with these bugfixes?
https://www.npmjs.com/package/@pdftron/pdfjs-express-viewer still has the unpatched 8.7.0 version.
Hello twidel,
We will update the NPM with the latest build
Great, thank you @tgordon. Can you reply when NPM has been updated? Will it have a new version?
hi @tgordon , is there any ETA for updating NPM for PDFJS Express with the fixes for the mentioned issue? I’m running into the same problem.
thanks a lot
These patched files work for me as well, thanks!. Will you be able to update the npm soon?
Hello samiam,
The npm has been updated
Best regards
