I followed the steps in the documentation for setting up PDF Express Viewer in my Vue application. It works as expected locally, but when I deploy it on Azure VM (behind IIS), it fails to load a PDF file. The UI is correctly rendered, constructor’s callback (.then(instance =>) is successfully invoked, but when I provide a file (via instance.UI.loadDocument(…)) it throws the following error:
NOTE: The same happens with few versions (8.4.0, 8.2.1, 8.1.0)
The component should successfully load and display the PDF file.
Every document.
N\A
mounted() {
path: '/assets/pdf-viewer',
licenseKey: 'license_here',
extension: 'pdf',
}, this.$refs.pdfViewer)
.then((instance) => {
console.log({ instance });
this.pdfViewer = instance; // Stored and used for later loading documents
