I am using PDF.js Express Plus version 8.7.2 with the annotation feature enabled. My goal is to:
- Save annotations drawn on the viewer to a database.
- Load annotations back into the document from the database when revisiting the document.
I am using the following code for importing and exporting annotations:
Loading Annotations from Database:
javascript
Copy code
// After the document is loaded, we load the annotations from the database
instance.Core.documentViewer.addEventListener('documentLoaded', async () => {
const xfdfString = await loadXFDF(docId);
await instance.Core.annotationManager.importAnnotations(xfdfString);
Saving Annotations to Database:
javascript
Copy code
// When the "save" button is clicked, we export
// the annotations and save them to the database
saveButton.onclick = async () => {
const xfdfString = await instance.Core.annotationManager.exportAnnotations();
await saveToDatabase(docId, xfdfString);
Questions:
- Are
exportAnnotationsandimportAnnotationsAPI-dependent calls, or are they strictly handled on the client side?
Specifically, do they require API usage credits, or are they independent of API limits? - Is there a limit on the size or complexity of annotations when using
exportAnnotationsandimportAnnotations?
Will exporting a large number of annotations or importing a large XFDF string impact the viewer’s performance or cause any issues? - Are there any recommended best practices for handling large XFDF strings when saving to and loading from the database?
- The annotations should export as an XFDF string without any API limitations or size restrictions and should load back correctly into the viewer without performance degradation.
This is a general question, applicable to any document.
N/A
Provided above.
