enableViewportRenderMode() functionality
|UI version|‘8.7.0’|
|Core version|‘8.7.5’|
|webviewer.min.js|‘8.7.5’|
Is enableViewportRenderMode() integrated into the viewer by default ? although I do see some form of virtualisation in the viewer when viewing large and complex pdfs, however when I tried to log console.log(Core.documentViewer.isInViewportRenderMode()); returned false.
console.log(Core.documentViewer.isInViewportRenderMode()); would return true
All documents
Prefer not to disclose
Thanks in advance !
Hello kin.jx
ViewportRenderMode is specifically when the zoom makes the page appear to be “bigger” than the viewport.
If you zoom in then log again, you should see it to be true.
In the image below, the first log is when the page fit within the viewer, the second log is when I zoomed in so the page is “bigger” than the viewport.
Thank you for the detailed explanation — that really helped clarify things for me.
I had misunderstood the usage a bit, especially since it looks like enableViewportRenderMode() is enabled by default. Appreciate you taking the time to clear that up!
Hello kin.jx,
Glad I could be of assistance.
