Why is my DocumentContainer so small?
I’m using latest version of PDF.js Express and following the manual integration example from here
But my viewer appear tiny ( see screenshot here )
What am I doing wrong ?! here’s my html :
<!DOCTYPE html>
<html>
<head>
  <title>PDF.js Express Viewer</title>
</head>
<!-- Import PDF.js Express Viewer as a script tag from the lib folder using a relative path -->
<script src='pdfjsexpress/lib/webviewer.min.js'></script>
<body>
<div id='viewer' style={{"width":"1024px","height":"600px","margin":"0 auto"}}></div>
<script>
    path: 'pdfjsexpress/lib', // path to the PDF.js Express'lib' folder on your server
    initialDoc: 'pdfs/sample.pdf', // lidl
}, document.getElementById('viewer')).then(instance => {
    //instance.UI.setTheme('dark');
    Core.documentViewer.addEventListener('pageNumberUpdated', (pageNumber) => {
</script>
</body>
</html>
Hello pdfjs.express,
The container’s CSS wont allow the Viewer’s CSS to fill the container.
Please review your CSS!
Thanks I figured it out, it might be an idea to reference the required css file in the example page though.
I have same problem. How did you fix it?
Thanks.
Hello ufuk,
This depends on how youve implemented your CSS. Check the width/height of the container and the parent container to ensure it can expand to fill the container.
