Export Annotation to CSV and Natural Language Processing (NLP)
we see a good use case in the PDF.js at the moment for our product. However, PDF.js Express seems not to provide a output of the highlighted text in a csv file.
Do you have also a product where NLP features (semantic search etc.) are incorporated like semantic annotations. An example is: Software · Explosion
Robert
I believe PDFTron would be a better fit for you than pdf.js express:
Here is an example of semantic text-compare in PDFTron WebViewer:
and the documentation:
Thanks for your answer. One follow up question. Do you have any documentation on how to integrate AI models in PDFtron artificial intelligence / PDFtron AI? PDFTron Systems Inc. | Document-understanding
Thank you
For PDFTron support, please contact: PDFTron Systems Inc. | Support
