- Can the default resolution be configured for pdfs of different sizes?
- Can a horizontal scroll bar be added for landscape documents that do not fit the page width?
- Can the toolbar be made persistent so that it is visible even when a user scrolls to the end of the page?
- Defect: When a document is zoomed the watermark becomes smaller and it disappears after 200%. Watermark should be displayed at all times and be in accordance with the document’s dimensions.
- In mobile view, search icon is not immediately visible on the toolbar. User has to click on the options icon to see it. Can the position of search icon be changed on the toolbar so it is immediately accessible.
- Defect: Clicking on settings icon in the mobile view opens the settings menu at the bottom of the page. It is not visible until user scrolls all the way down.
- Defect: In the mobile view, toggling from search result screen to document shrinks the contents of the document to a very small size.
- Can the default page transition option be the selected option on page load?
We are trying to determine if any of these are doable.
We tested it against several documents
